I'm having a serious problem with my OmniPro II experiencing random "resets".  Log shows "System Reset".  I've contacted HAI but haven't received anything useful.  I understand that the resets do happen occassionally but I'm experiencing several (2 to 5) per day now with NO pattern.  Armed, Disarmed, nothing seems to make a difference.  I've reset RAM, reset EPROMS, reuploaded all of the setup and programming multiple times.  Tried running with NO programming lines.  The "problem" is not the resets, the problem is that sometimes they cause really strange results including: complete disarming of the system, corruption of programming (buttons no longer work manually or scheduled), weird values in flags (not just 0 or 1 but 72,83, etc.).
The system is about 9 years old and has been ROCK SOLID until now. Running version 3.9 of the firmware. Battery levels are in the 220's. There are about 45 zones, six new style HAI thermostats, smoke detectors, wireless adapters, etc. I use X-10 (don't laugh) for lighting, it's worked perfectly for many years (I did have that one bad power strip though!).
NOTHING CHANGED, at least I didn't change anything. All zones look good, all thermostats work, all programming works, the control panels are fine, I use SnapLink on IOS which works great to access the system, I have HaikuHelper running on a Mac (it's not the problem, I've turned it off as well). The whole system is connected to my gigabit network sitting behind a rugged firewall. I have no network problems.
The challenge is that the system, literally, runs my 6500 square foot house. Lighting, security, thermostats, everything is run by the system. Without it, we're lost and, of course, have NO SECURITY. It was professionally installed back in 2003, I added a few zones, features in the next year or two but, except for programming lines, hasn't changed from a hardware standpoint for many months. I have replaced 5 of the six keypads with the new blue-button styles and one thermostat (old one died) last year. Nothing in the hardware has changed in six months. There is also an expansion chassis which was used for the relays to control garage doors, I disconnected that to see if it would help, it didn't.
Obviously I could simply replace the main board (what a HUGE job that is standing on a ladder) but I'd really like to know if anyone else has experienced anything like this and what the resolution was. I hate to just throw money nd time at it without some kind of direction.
Could it be something external, wiring, bad connection, bad thermostat (even though they all work), bad keypad (again they all work).
Any and all feedback and/or suggestions would be appreciated. Thanks.
