Hi everyone, looking for some advice for controlling outdoor lighting. We're in the process of building a pool. My entire house is automated with z-wave (40+switches) and controlled via homeseer (and triggered by an Elk M1 for various events).
I have used the outdoor zwave switches in the past for christmas lighting. While they are very robust, the range is not exactly confidence inspiring. The current zwave controller is in my equipment closet, along with the ELK and homeseer computer, on the second floor with easy access to an exterior wall and the attic.
Here is the basic layout of the pool area:
There will be low voltage wiring in all flower beds and around the outside of the pool. The wiring can be terminated at the pool equipment location, or in a storage room (covered and shielded from the elements) under the deck. There will also be a few outlets scattered around that we may use for christmas lighting.
If z-wave had enough range, I could just put a zwave relay switch in the storage room to control the low voltage lights, and use the outdoor zwave switches at the various outlets around the pool to control the christmas lights. Something tells me this is not going to work.
I could always go with UPB, easy to mix and match with homeseer. Another long shot option is to use our Aqualink pool controller to control the low voltage lighting and outlets (it will have a bunch of free relays) - but as far as I know homeseer and the Aqualink don't communicate 2-way (very surprised no one has written a more robust integration to homeseer yet, I would gladly pay $50+ for it). One last idea is to run an Elk relay expansion board down there via Cat 5 and figure out a way to use those relays to control lighting.
Any thoughts?
Any thoughts?
