Historically here used wired Optex outdoor sensors which worked well for me.
Last year tried a custom wireless 433Mhz MQTT solution integration to OmniPro 2 panel using the following hardware.
1 - Sonoff ITead 433Mhz RF bridge upgrading radio / base OS to Tasmota
2 - Outdoor long range 433Mhz PIR
3 - ESP01 wireless relay base OS to Tasmota plugged in to one zone on the OmniPro 2 alarm panel (It is mounted outside of the OmniPro 2 can in the basement)
Using Homeseer and Home Assistant here with MQTT / OmniPro 2 integration. I did this in May of 2021. The PIR uses 3 batteries and they are still working fine outside here in the midwest with cold and warm extremes. I do not remember where the Tasmota RF hub connects to the WLAN in house network.
Steps:
1 - capture code from 433Mhz PIR
2 - write a rule on the RF bridge to send MQTT on reception of motion from PIR
rule2 on RFReceived#data=13689994 do backlog publish2 Sonoff_Bridge/Motion1 ON; ruletimer1 5 endon on rules#timer=1 do publish2 Sonoff_Bridge/Motion1 OFF endon
rule2 1
The data 13689994 is the RF code for the 433MHZ PIR. You can add more RF sensors and extend the rule to include sensor 2, 3, 4, ...
console display:
Works great.
07:41:25.926 MQT: Sonoff_Bridge/Motion1 = ON (retained)
07:41:26.179 MQT: Sonoff_Bridge/PIR/RESULT/RESULT = {"T1":5,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
07:41:31.426 RUL: RULES#TIMER=1 performs "publish2 Sonoff_Bridge/Motion1 OFF"
07:41:31.433 MQT: Sonoff_Bridge/Motion1 = OFF (retained)
3 - write a rule on the ESP01 to close switch on reception of trigger from RF bridge.
rule2 on POWER1#STATE=1 do backlog publish2 Omni/HikVision_PIR/Motion1 ON; ruletimer1 5 endon on rules#timer=1 do publish2 Omni/HikVision_PIR/Motion1 OFF endon
rule2 1
I called it Hikvision_PIR because I was doing the same with the Hikvision Doorbell PIR except that it was too sensitive so I quit using it.
ONVIF messages converted to MQTT messages using a Python script.
Console displays:
Omni/HikVision_PIR/POWER = ON
07:49:07 RUL: POWER1#STATE=1 performs "backlog publish2 Omni/HikVision_PIR/Motion1 ON; ruletimer1 5"
07:49:07 MQT: Omni/HikVision_PIR/Motion1 = ON (retained)
07:49:07 MQT: Omni/HikVision_PIR/RESULT = {"T1":5,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
07:49:08 MQT: Omni/HikVision_PIR/RESULT = {"POWER":"OFF"}
07:49:13 RUL: RULES#TIMER=1 performs "publish2 Omni/HikVision_PIR/Motion1 OFF"
07:49:13 MQT: Omni/HikVision_PIR/Motion1 = OFF (retained)
Currently the PIR triggers:
1 - Microsoft SAPI speech notification via Homeseer
2 - Amazon Alexa speech notification (to all or just one Amazon Alexa device) - via Alexa Media plugin for Home Assistant
3 - Coach lights / Landscaping lighting after hours
4 - automation lines on the OmniPro 2 panel
