I'm just starting out with my first home automation projects: structured wiring and lighting (retrofit into an existing house). i don't have a lot of experience doing electrical work. i bought a pcs starter kit this wknd so i could try it out.
I believe at this point I've settled on UPB as the lighting technology i will use. i intend to replace ~30 existing switches, mostly incandescent and mostly dimmers. some are 3-way switches.
here are my questions:
what brand: pcs, hai, or sai?
- i've read that gen2 switches are preferred for noise immunity and smaller delay. i've also read that sai switches w/ recent firmware can also have a smaller delay. is the delay in the (suitably configured) newer sai switches comparable to that on the pcs and hai gen 2 switches? any word on whether sai is coming out with gen2 switches?
- the thing i like about the sai switches is that they have a load-bearing multi-scene controller. as i'm doing a retrofit, i don't have room in existing J-boxes so I don't want to waste a gang on something that isn't carrying a load. if i don't go with sai, what are my options: can i turn a 3-way switch into a 2-way switch and, instead of using a slave, put a pcs or hai multiscene controller in its place? do the other guys (hai, pcs) plan on releasing a load-bearing scene controller?
- i was told by the guy who sold me that the sai swtiches don't report back their status but the pcs and hai switches do. but i haven't been able to find any confirmation of this while researching online. can someone confirm/deny that sai switches are functionally different than the pcs and hai ones?
- are there any issues w/ using a mix of pcs, hai, and or sai switches? i surmise the basic functionality works. how noticeable are the cosmetic differences?
phase couplers and surge suppression
- i have the phase coupler that came in my pcs starter kit (PPC1). looking online, i see the sai starter kits advertise a phase coupler that goes in the breaker panel and appears to take the place of a 220v breaker. this seems like it would be a nice clean install. what do people do with the pcs phase coupler: do you put it in its own box, or do you find a way to put it in the breaker panel somehow?
- are there any issues w/ making upb work behind surge suppressors? do installers typically use whole-house surge suppression and avoid using surge suppression strips?
interface module and automation/security controllers
- i'm planning to add a security/automation panel like the elk m1g or hai op2, and leaning toward the elk. are there any issues w/ elk's support of upb or any reason why hai op2 + hai switches is an easier combo to install/use?
- what do i need to interface the elk with upb? is the PIM-R (RS232 version) sufficient, or is the usb version preferable?
.. anything else i should know about?
