v1rtu0s1ty
Does that mean the cat5e being used by elk keypad doesn't get terminated to the M1XIN board? It's because you're now saying to also pull CAT5E cable.
Thanks guys!
Thanks guys!
Does it change the way M1 looks at the connectivity when expanders are present? Say contact sensor in 2nd/Floor connected to an expander, isn't M1 going to pinpoint which one is really is? I'm assuming that there is like a sub numbering in M1 which will help us troubleshoot just like ATSC local broadcast channels in my area, 11.1, 11.2 and 11.3 for PBS.ORG. Channel 11 but it's got 3 sub channels.toymaster458 said:Just my 2 cents. I would make the head end just that. A head end. Make everything a home run and not to have seperate panels though out the house.
Personaly when I have an issue I do not want to be running around the house troubleshooting. Plus come the middle of summer going into an attic is not what I have in mind of a good time.
You still didn't answer.Digger said:One Cat 5 would be for Keypad. The rest would be for other things as time goes on such as possible Camera's etc. I like to pull extra wire for future use. I did that and used almost all of them already and wished I pulled more.
BraveSirRobbin said:I'm using an M1DBHR and wired it (bench testing right now) according to THIS schematic.
I'm sorry, but I didn't get what you mean. What would I terminate?I noticed that you have two zone expanders and two keypads. I would just terminate each into its own output/zone with the expander (assuming you are placing that hub in the same location as the ELk M1G).
I was told to use 18/4 wire when connecting M1XIN to M1DBHR. What wire should it be though?Also, I'm not understanding totally why you are running 18 gauge wiring for your data lines, but I didn't read the entire thread...Â![]()
I'm just curious, what wire did you use? I think the 18/4 is going to be used for power. That's the other part that I need to clarrify also.Well, I don't want to intrude as I'm not familiar with your entire situation as the others who are giving you advice are so I'll just let that one rest.
It's all in the addressing of the zone expanders and has nothing to do with various ways you can wire them into the bus.v1rtu0s1ty said:BraveSirRobbin,
Using the diagram you shared to me above, will a single sensor still be dedicated to a single zone? it's because, your 2 M1XIN are using the same bus.
Thanks.
Yep, for sure I will do that. The reason I have been asking is because, I'm finalzing my wiring. Drywalling is on June 12. I don't have enough time. And also, I will be only allowed to wire on June 10-11. I'm planning to start at 6am then go home at 7:30pm, then do the same on the next day.BraveSirRobbin said:Here is a picture of the bench test setup. The data base hub is on the right above the right most keypad.
I would "highly" suggest taking the time to bench test your setup and get used to the software before you install the system!![]()
Yep, I noticed the addressing earlier.BraveSirRobbin said:It's all in the addressing of the zone expanders and has nothing to do with various ways you can wire them into the bus.v1rtu0s1ty said:BraveSirRobbin,
Thanks.
So as long as you properly address the zone expanders they will have consecutive zone numbers (look at my schematic again).
