Your life would be so much simplier if you would wire the system with normally closed zone definition instead of EOL zone definition. Multiple switches connected to a zone input must be wired in SERIES, NOT PARALLEL as your drawing showed. If any switch opens then entire circuit opens.
The advantage of EOL over normally closed circuits is to be able to detect the wire being shorted. If you need that capability, use EOL.
A normally closed circuit keeps the circuit pulled to negative, which gives better noise and lightning immunity than EOL or normally open circuits.
