I have did a couple of google searches looking for serial controllable powerstips.... The "best" that I have found so far seems to be this one:
CPS Power Strip
The price is buried at the bottom: $115, plus a $18 for a DB9 to RJ11 serial cable.
Note: While this powerstip has 6 outlets, it only has 3 relays (a relay controls a PAIR of outlets)
Background:
I have a Time Warner cable modem, a DLink router, a DLink switch and other misc equipment plugged into a UPS. I have a "watchdog" Powerhome macro that periodically checks for "connectivity/functionality" of each device. When a device appears dead, I want to be able to power-cycle it.
Right now my biggest issue seem to be the cable modem. About once per week (or less often), I will wake up to find that my connection to Time Warner is down (no internet). Manually power-cycling the modem always seems to make it re-connect. =>This is what I am trying to automate. If there were a "software" command that I could issue instead, that might work (but, I am aware of no such way to interact with TimeWarner's cable modem)
So, has anyone lese seen or used a "controllable" powerstip that is either cheaper, or may have other unique features that might fit this situation? I am not interested in rack mounted units (I have no rack, and no plans for one). Thanks!!
CPS Power Strip
Background:
