roussell said:
At any rate, thanks for the great write up of your system, Housebot in particular. There isn't a lot of activity on the HB site and very few people share their setups. You're right on about Scott, he has totally devoted himself to the app and it shows. HB is one of the most stable windows apps I have personally used.
Terry
Although you are right that there's not much day-to-day activity on the HouseBot forums, there is a wealth of knowledge in the various posts that have been made over the last few years. The are a few useful features in HouseBot that aren't really documented but they get discussed in some of the posts. The forum search tool is a good friend of mine
I agree that I'd like to see more sharing of setups. Part of the issue is that there's not currently any place to upload things like that. The other issue is that due to the way HouseBot works internally it can sometimes be a bit challenging to share a complete configuration.
You can easily share a "theme" (this is the HouseBot name for the GUI portion of a software remote). This lets other users see your "look". The problem is that another user can really *use* your remote (the "feel") unless they have all the same devices installed on their system that you reference in your theme.
On the other hand, HouseBot has a very nice export feature that allows you to share most anything you want to (devices, themes, tasks, etc). In the past when I've wanted to share something I made a copy of one of my themes and removed all the things that were specific to my devices. Then I did an export and others were able to check it out.
As for support, Scott is absolutely amazing in that respect. He's been known to do an update or fix for a reported problem in as little as a day or two. I also agree with you - the current version is *very* stable. A little while back I was doing an "uptime" test. I had it running for 32 days in my *very* active configuration (software remotes with touchscreens in five locations) and it never went down. I finally had to shut it down so I could install an update that Scott released. If I hadn't shut it down I suspect it would still be running continuously today.
I made a good post on the HouseBot forum that details more of the things I'm doing with my installation. I would include a post to it here but the HouseBot forums seem to be down right now
. I'll post the link when the forums are back.
-- Dave
