I am installing an m1ez8 to replace a brinks system that appears to have been incorporated into builder installed wiring (built 2003). There are no EOL resistors. The only components I reused are the wiring and the various contacts (door and window contacts with one motion sensor). I have one m1KP with the jumpers installed on the board and on the keypad. I plan to add a m1KPAS once the system is set up.
When I first connected power, the power light came on steady and the status light blinked continuously (a little faster than once per second. At first, the keypad displayed a line of black squares across the first line. After a few minutes, characters started streaming across the top line (looks like machine language???). I have disconnected the power and battery.
I searched and cannot find an answer to this problem. I am concerned that I have a bad board or a bad keypad or that the firmware is corrupted. I do not have the module to connect via serial port or ethernet so my only access to the system is via the keypad.
Any ideas? I am new to this, so be gentle.
