If you are using a touchscreen Mike adding mouse over audio isn't as easy as you usually have buttons configured as clickable..so with a touchscreen it would be sorta hard to actually drag over each thing and have it play background music..touching a button to do this however would be much easier.
Basically with Mainlobby unless you know Flash your going to pay for anything custom to do with Flash..while its very simple to make buttons and convert graphics to work in flash and Mainlobby when you start trying to do actionscripting and want drop down menus, interactive audio and anything else fancy that you might see on a custom website your going to pay... unless someone has a huge heart and decides its your lucky day and will do programming for free.
It would be possible to have mouseover audio in mainlobby if you chose to use the program with a mouse..I would think it would be especially tricky to drag on a touchscreen and place it over a link and have it play audio without invoking a button press at the same time...you could set your touchscreen software to work differently for drags but then it might effect navigation for other things in negative ways.
Flash is a nice programming language but if you don't know it you'll be paying for it and the rate is far from cheap and you'll have to hope Cinemar will be kind enough to expose code to you so things will work, they were uncooperative with me in requests for the feature of user created graphic librarys in Flash so don't expect them to offer functionality if they can profit from it somehow.
