hult
Oh it's worse, I bought one of the MarcHult ones too![]()
My concern about using the AP800 is:
1) I dunno if it actually works (as-is auction)
2) For the tiny amount of $$ that this is ($60 for the one I got, $25 for the MarcHult one) I'd rather keep 2 seperate systems until I get it all stable, then look into combining it.
#2 is actually the bigger issue - i've spent more time pissing around on things only to realize that the problems are inter-related and i'm stomping on my own feet. I'm sure I can sell off the stuff I don't use, I'm sure I can get most if not all of my $$ back (given how cheap this was).
Sounds way familiar ;-)
2-3 years ago I worked up a list of devices to give or lend to Dean Roddey for CQS driver development. The Ivie mixers were near the bottom of the list and never got sent to Dean although others did.
The ASCII command set to control them is simple enough, and the graphical user interface would be similar for any matrix mixer. So Dean might now have time to do it. I'd be glad to sent him a pair of 884PW's and compatible Ivie PW530 1/3-octave equalizer.
The 784PW is the same as a 884PW but without auto-mixing/gate and has fewer LEDs on the front panel. The current model, the 884+PW is identical to a 884PW but with an RS-232 interface also as well as RS-485. If I recall correctly, I was able to talk to the Ivies through both an 8-port Comtrol RS-232/422/485 and a $15 generic RS-232 -->RS-485 convereter. I'd send Dean the original equipment Ivie RS-232-->RS-485 converter.
Ditto if there is someone that wants to work up a HomeSeer plugin.
Right now I'm focusing on HomeSeer development to replace my aged Savoy CyberHouse system, but longer-term plan is to add in CQS for AV aspects.
Marc
