az1324, no doubt, it really took me by suprise and it was a hecktic day, I didn't even think about rebooting but I should have.
Cai, This board has been up and running flawlessly for a week or two. This was the first problem I have had with it. It has been running flawlessly since.
I have been going over in my head the events that took place before it happened. I had just received 3 boards back from you which were firmware updated. I opened Windows IE and typed in the address of this board to verify the address and firmware version. Once verified I changed the last 3 of the ip address in the address slot in IE to switch over to one of the new board addresses, without closing the window or anything. Once IE was displaying the new board info I made some changes to the General tab (changed IP, time etc.), then saved. Then typed in the last 3 numbers of the next IP address in IE address slot and made same changes to the next board.
About 4 or 5 minutes elapsed when I was notified of a problem with the temps. I logged back into the board and noticed t5,6,7,8 reading in C. When I clicked on the Temp Setup tab all the check boxes were checked for F. Went back to the main page and t5-8 were still reading C. Went back into Temp page and checked all the C boxes. Hit save. Then checked all the F boxes then hit save again. When I went back to the main page all readings were once again reading in F.
Not sure what caused the issue but could it have had something to do with opening the browser for that board, then just changing the address in the browser address bar to switch to another board then making changes on that board and saving then repeating with 2 other boards?
