Well, there are 6 gang faceplates so there has to be 6 gang boxes. Probably a special order at an electrical distributor. Most modern homes I think they are trying to get away from wall clutter. Can't use use multiload switches, or scene switches to reduce the number of gangs needed?
I know their are metal boxes that can be put together to make a 6 gang box but I need a plastic box for zwave to work
it's best.
Also reducing wall clutter is a good idea but I still need to install a switch for the scene controller to control. They do not
make a multi-load zwave switch. So I need a box for each load controlling switch.
Mark
it's best.
Mark
Can;t yo uhave a 6 gang 'out of sight' and then a 1 or 2 gang scene switch?
Allied Moulded makes a 5 gang box part # 5305-nk , also I have found up to 8 gang "rings" to combine line and low voltage under 1 plate from OEM Systems. I have used a 8 gang hi/low box (not just a add on ring)and plate which came with divider plates which was made by OEM . I am not sure if they still make it but look here and you can see several large gang setups and part numbers and you might be able to track it down some where.http://www.hometech.com/acrobat/sy-hilo8.pdf P.s. check into getting it engraved @ www.rightplate.com as well . good luck .
