When I pre-wired my home (20 years ago), it looks like I ran two 22/4's (solid core, not twisted at all) to each keypad location. They are all home-run back to the location I originally planned on locating the box (at the time, a Moose security controller). I have a M1DBH that I plan on using to terminate two remote boxes and I would like to use it for my keypads, too. It looks like the existing wires to the keypads are stapled in the walls so I doubt I can use them as pull strings to pull new cat5 wire. Can I use the existing wire for the keypads, or will it cause problems because it is untwisted? I've decided to put the M1G in a different location than originally planned, so I will need to extend the existing keypad wires. I'm thinking I should cut the existing wires as close to the keypads as possible and splice in cat5e to home-run to the new M1G location. Will that work okay?
Ira
Ira
