The guy doing the LV wiring (he did HV wiring for 20 years) says that the only reason he's not running the cat5 inside the box is b/c of the inspector. I am sure that if the inspector is ok with it then the LV will be in the same box. I don't know enough about it to comment either way but I'll definitely be reading up on it. With that said, there definitely seems to be a hard line between people who think it's no big deal to put the two in the same box and the others who stay away from this.
Also, I should've done more research on these switches b/c man they're expensive! I thought they were in the $100 range but when you factor in 3 switches controlling a light, that's one main controller switch and two aux switches. This is roughly $450-$500 per 3 or 4 way light (minimum) and for simple single switches it's roughly $300! Of course, there's definitely more expensive brands along with similarly priced brands (UPB for example) but I can definitely see the draw in going with Insteon/Zwave/etc.
I'm still having the switch locations wired (a lot of them at least) and may have two or three lights automated. The rest I can install down the road it seems as long as the wiring is there.
