A couple questions on proper wire usage:
1 - I purchased some Southwire Thermostat 18/2 brown solid wire from Lowes. Can I use this wire in places where 18 AWG is called for? For example wiring the ELK transformer to the control. Or wiring the doorbell sensor to the control. Or wiring the battery to the control. I understand wiring smokes should/must be firewire.
2 - I want to run speaker wire to my keypads to power speakers. Is the 16/2 stranded wire labeled 'speaker wire' sold at Lowes acceptable? The wire has a clear jacket around it. My wire runs to the keypads vary from 20 to 60 feet.
3 - In general, is it better to use 18 AWG solid vs stranded for panel hookups? Seems like stripping the solid wire would be 'better' than stripping the stranded wire since using solid would eliminate the chance of cutting a strand.
Thanks for the help!
