linuxha
pete_c said:Thank you Neil.
No changes were done to the core Homeseer 3 relating to using Mochad.
Original X10 plugin was a quick port over from legacy Homeseer 2 plugin. Mark (mentioned above) rewrote the plugin and it is now working better than it did in the HS2 days. (IE: last X10 plugin for HS2 while it worked had issues which you could see using a serial sniffer).
Only changes that I see here (well and I do not have a CM15A) is relative to Debian (IE: Wheezy to Jessie to Stretch and Ubuntu 14.04 to 16.04).
Your Mochad version is 6 years old and the one utilized by Homeseer 3 is probably around 10 or more years old.
I actually can't recall the changes any more. I know I added IPv6, I may have fixed a few warnings but if anyone finds issues I can update as necessary.
I hope I still have my notes on the CM15A. There are a lot of features that we figured out (or mostly figured out) that X10 failed to share with us. All pertaining to the wireless portion of X10.
