The needs out there are for voltage sensors and current sensors mostly. !-wire bus provided the fault tolerance for measurement and communication. For any other thing to sense, mostly can be converted into voltage or current. However, because 1-wire slave device is patented and not licensed to any third party, that makes new sensor using 1-wire bus difficult.
Some of those chips, like DS2450, are discontinued by Dallas, because its low demand. When they say low demand, that means less than 2 million chip a year. However, the needs for DS2450 is actually exist. The reason for DS2450 is low, simply because its output is not very stable, easy to read bad result if PCB layout is not perfect. If someone makes a good design, I am sure there will be a lot need for it.
