CAI_Support
Its datasheet does not show what kind of output it having. However, most ph sensors output voltage. You may need Ross' terminal board with amp to read fine ph value change. If you played with Ph sensor before, you probably know all PH sensor requires periodically calibration with pure water, if you want to have very accurate reading. If just measuring the PH value in soil, then you don't need to do calibration often.
