I'm hoping someone from HAI can help with this problem.
I added a 10A17 serial board to my OMNI II (not OPII, not IIe). The purpose was to connect it to a Leviton Vizia RF controller (never got that far). It is the second expansion board, the first being a hardwire expander. The HW expander is module 1 with jumper in 1st position and setup as Hardwire Expander. The serial expander is module 3 with jumper in 3rd position and is setup as OMNI-LINK.
I initially tried setting these settings through PCAccess. When I set the serial expander to OMNI-LINK, PCAccess crashed. The error mssage disappeared too quickly to see what it said. Subsequent attempts to connect to the panel via PCAccess gives me the error message: "Unable to open socket (50)".
I disabled any apps from starting on the PC, verified that Comm 1 was open and tried again. Nothing.
I went to the console and re-set all expansion settings: Module 1 = hardwired, module 3 = omni-link. No luck. I tried powering down the panel again and restarting - same result. I've tried diconnecting the serial expander and removing the settings via the console, no luck. Still get "Unable to open socket (50)".
Any suggestions?
Rick
EDIT: Running firmware OMNI II 3.2B and PCAccess v. 3.2.0.543
Any suggestions?
Rick
