filename : custom_blockbuster.txt
version : 1.1
description : grab the latest video releases from blockbuster.com
author : electron
instructions:
1) copy this script to the homeseer\scripts directory
2) create a virtal device
3) create an event to manually run this script
4) setup wizard will kick in and help you setup the configuration
5) fine tune your event, and specify the mode you want to use (see below)
6) the config file can be manually edited, you can find it in the config/custom_settings.ini location
modes
1 -> only update device string
2 -> only announce new releases for today
3 -> only email new releases
4 -> only save to disk (saved in the ini file)
d -> turn on debugging mode
* modes can be mixed , example: 134d (will use mode 1, 2, 3 and turn on debugging)
syntax: custom_blockbuster.txt("main","mode"), if no mode has been specified, it will automatically select 1
usage examples :
* call with your cell any time to find out new video releases while on the road, saving time & money when nothing interesting is available
* announce todays new movie releases, as part of the good morning routine
* email yourself on a weekly basis to find out when your favorite movie will be released
* use mode 4 to save the new titles to disk, allowing you to read the file and display the titles on your tv, betabrite, etc ...
Changelog
version 1.1 (08312003): added support for multiple modes at the same time
version 1.0 (08282003): added debug/email/disk features, added setup wizard, cleaned up code
version 0.9 (08262003): created script
version : 1.1
author : electron
instructions:
modes
usage examples :
Changelog
