[Blogs] If the shoe fits - Changing Gears with Virtualization
Status
Not open for further replies.
CT Droid
CT Bot
So I got to work over the weekend with my virtual server. I ghosted my install of Server 2003 and installed ESXi server to start the virtualization process as I described in my last post. I was able to pass through the hardware I needed to for each of the guest installs, but I was unable to get ESXi server to recognize my onboard RAID controller. I had planned on putting all the Virtual hard drives on my Raid drive. I tried and tried but was unable to find a driver that ESXi would take and recognize it, so I just moved on. I would just install the virtual drives to the local drive and worry about space later. Hard drives are cheap, right?
Well, I popped in my Server 2003 disk and started the setup process. Everything was going great, but then Windows told me it was unable to detect any hard drives that I could install to. Not even the virtual drive I had created and assigned on the local drive. Interesting.
After a couple of hours troubleshooting why Server 2003 couldn't find it, I thought, I'll just install server 2008 to avoid the problem and upgrade at the same time. Well, Server 2008 showed the same problem. It is probably something I am doing, or not configuring correctly, but saturday night I thought this issue combined with a rumor I heard at work that we will be launching our virtualization project on Hyper-V later this year changed my mind and I decided to try Server 2008 with Hyper-V. This would also allow me to avoid getting a NAS because I could just install a virtual file server to handle the load. I installed Server 2008 Core, simply because that was what was recommended for Hyper-V, but that was a mistake. Having to do everything by command line lead to a bunch of googleing.
Back to the drawing board. I ghosted Server 2008 Core and went about installing Server 2008 R2 Full. I got it all installed, configured and updated, when my wife wanted access to some files that would have been contained on the Server 2003 Image. Sigh. I ghosted my Server 2008 image, re-applied my server 2003 image, got her the files, then it was time for bed.
So at the end of the weekend, I started with an installation of Server 2003, and after 2 full days of tinkering, i ended up with the EXACT SAME installation of Server 2003. Productive?
Status
