Would like to compare notes here is the link to my files on same subject.
http://www.freedrive.com/file/1581169
[email protected]
So you have your Webcontrol board functioning as an enviroment control device? Really nice notes btw, lots of things hardware/mounting wise i'm going to look into if i can figure out how to program the relays. I abandoned this project a few months ago, realizing i imagined it would be simple to program and setup, but got lost in the programming (no expirence), and recently decided it would be useful in a indoor terraneum i'm growing succluents in atm.
I have the board running, humidity sensor, temp sensor working and i can log them remotely. I have a two relay electronics salon rly-1 i want to set up to turn the lights on and off with, as well as a temp adjusted fan to get my feet wet in this project. If i can get that working prob will look into adding more relays to control a heater or something else to help with humidity when it goes too high. When the lights are off it gets a little too humid in there, if i can adjust the fan or have a heater turn on in conjunction with a fan that would be ideal.
But before i get ahead of myself, could you offer some help to a noob concerning programming it via plc to get a timer set up with that dual relay board?
All i need is a daily 6pm on, 8am off schedule. I can wire the relays up fine, i just have no expirence or knowledge in programming the box. But i want to learn. A walkthrough on how to program the board for the lights would be very much apprecciated if you don't mind. If i can do that i don't see why i can't learn how to set up a humidity/temp/fan control system as well.
Just need the basics on how to do this described in a programming noob firendly format, or a link to where its already been described. Also any reccommendations on learning how to write code for it coming from no expirence at all would be cool too. if anyone can help here its apprecciated.
Thanks-
Edit- got it connected to xapmcs and think this might be an easier way to program the box. If i set a configuration in the xapmcs webpage, does it save to the device so the program stays after the computer with xapmcs is turned off?
