BraveSirRobbin
Moderator
Hi deltax153 and welcome to CocoonTech.
First of all, back up or ghost your system before trying any of the following (in case something goes wrong).
Read my first post's instructions again. I show where I downloaded Case's plugin from THIS site (zip file). The ocx is contained in that zip file.
You need to manually register that OCX file by using Regsvr32 command. You do this by going to your "Start", then "Run..." command buttons and enter the following in the run command's dialog box (assuming you copied the ocx into the Homeseer directory):
Also note that I used the X-10 drivers that Jeff Charger had and not the one currently posted on X-10's site. Those drivers can be found HERE (save that file to your hard drive then run to install the X-10 drivers.
Its finicky, but I finally got it to work!
regsvr32 "c:/program files/homeseer/hspi_CM19A_USB.ocx"
