Keith White
If you have a lot of x10 and have issues you and are using a TW523 then you need to check this out. It has made my life much better.
Ketih Whtie
http://www.appdigusers.com/forum/showflat....ge/0#Post187821
And I will have to hunt around to see where I saw that it didn't... I may have simply misinterpreted it. I think you were the one that suggested this in the thread where I was considering switching from x10 to Insteon, and I THINK you may have also been the one that said it improved the signal both ways. But I seem to remember reading somewhere where the guy who designed these making some comment to the effect that he originally intended on it amplifying in both directions, but decided not to out of concern that it could pose some kind of regulatory issue (like UL, or some other agency). I'll have to root around and make sure I didn't dream that.upstatemike said:I will have to hunt around for where I saw that.
I find it amazing that anyone would select "surface mount" components for a DIY kit! :lol:Care must be taken to properly align the tiny surface-mount op-amp before soldering
1- No it is not a TW523 replacement nor is it a boosterlinc. It is a point of use amplifier that will amplify the signal of any X-10 transmitter plugged into it to almost unimaginably high levels. This could be a TW523, Ultrasonic Command Console, or whatever.BraveSirRobbin said:Hmm, two things holding me back on this.
1) I first thought this was a "direct" replacement for the TW-523 or PSC05. Am I correct in saying that it is not, rather it is just an amplifier that plugs into an AC outlet? In other words, it operates a lot like SmartHome's Booster Link??
2) This statement in the instructions:
