Ok, thanks! I may just have to order one and try it out! It would be nice to be able to pump up the power for all of the critical transmitters with one device. When you say "it could go down by a factor of 2", I assume you mean lowering resistance, such as down to a 5ohm resistor?
I guess one of the things I'm having a hard time wrapping my head around is quantifying the negative effect of having multiple devices behind the XTB. From my perspective, ALL my devices are on a "shared bus", and therefore already represent a load to each other. I suppose the XTB somewhat isolates them from the rest of the circuit (and passes the signals between the "inside" and "outside"), and perhaps the XTB just can't pass enough signal inside for multiple devices? Do you expect the potential performance decrease to simply be one of reducing the improvement that the XTB offers, or actually reducing it lower than if the XTB weren't there at all? In other words, does the XTB somehow isolate what's behind it to the extent that if there's enough load behind it, it's not able to pass as much signal as just straight wiring?
