So its that time of year again.
Last month I updated the firmware to 5.2.10 on the Elk and 1.3.28 on the XEP.
The XEP is not configured for a time server, but that "shouldn't" matter.
So far, so good. At least it didn't change a week early.
If you'd like to monitor when the ELK changes, you can use the attached perl script. It monitors the XK packets, which occur every 30 seconds, and writes them to a log file (clockwatch.log). About 220K of text per day of logging.
2013/10/27_16:07:55 16XK0808161271013110006E; 20131027 160808 dst=1 dif=13
2013/10/27_16:08:25 16XK3808161271013110006B; 20131027 160838 dst=1 dif=13
The underscore between the date and time indicates the PC is in daylight time. It will be blank when the PC switches to standard time. Messages should also be written to the log when the PC and Elk switch between daylight and standard.
dif= is the difference in seconds between the PC and the Elk.
Rename to clockwatch.zip
View attachment clockwatch.pdf
I've been using Strawberry perl. You shouldn't have to install any additional perl modules.
