I am very close.  I guess I could put more detailed info on the SourceForge.net site, but it does not look like anyone looks there.
Here are the projects I feel I have to finish to put out the Alpha:
1. BUG - W800RF is not responding to DIM/BRIGHT correctly.  UPDATE: This has been Fixed.
2. I have made a client that will run off of any machine, but the Inteon Controller and the AB8SS both must run off of the same machine.  I need to seperate the AB8SS code and also test that it works fine without an AB8SS (not too big of a problem.)
3. Database conversion to MySQL has been done for a while, but I still need to generate the creation scripts for building the database on a new install.  I would also like to clean up the tables a little, mostly just a little renaming and cleaning up unused fields, etc.
4. Lastly, although the app controls Insteon devices fine, I relied a little too much on source code donated to me and did not study it enough myself and I seem to be stuck with DM v145 and I have not done any work on advanced features like Switch replacement, or spidering links, etc.  Now I will probably release with this flaw and see if someone else would like to help on it after I release.
I guess my biggest problem is understanding exactly how smooth this should be before I release the source.  If the initial release is expected to just work with no issues then I have a ways to go.  If I can release now and then work though the initial problems with a few people, then put out cleaner releases later, I would obviously release a lot sooner.
I had two people wanting to alpha test before I released code, but now I have not heard from them in some time.  Just because the source is not on SourceForge does not mean I am not willing to release it now to an individual that is willing to go through a rough manual confirguration and work with me personally on it.  My one local that wanted to pilot for me, if currently using Mr. House and is still using a CM11a and I am really not wanting to deal with different controllers at this point.  An Alpha tester must at least have an Insteon Controller, perferrable the USB version =)  as I do not have a serial one and have not coded anything for the serial version.
So to answer your question, briefly, I could have this thing in the hands of someone in the next day or two, if they are the right someone and are not expecting a polished product.  I am really ready for some help/partners, so sign up to my project if you are wanting to get involved now.  I will focus on the SQL install today because that would be the first step anyone will have to get through.
If anyone lives in Kansas City and wants to come over today and help, I will BBQ and I have about 6 cases of beer. heheh
Vaughn
