I have a setup which has all masters and one of three two way switches is high wattage (1000 Watts for the Chandelier). The other two are normal. (Insteon) but similiar. The two other switches are linked to the higher wattage switch but are not directly connected. The 3rd traveler wires are just capped from the old switch. I have a few set up in this fashion. The electrician in this house put in a switch for the second floor hallway lighting next to each door of every bedroom. Same for the kitchen having a light switch by every entrance. He also put in double boxes with single box mudplates in. A bedroom will have separate overhead fan, light and a switch (for the right side of all of the outlets in the room). I separated out the switch carving out the single duplex mudplate and installing a larger mudplate for two switches.
Whats nice about the new powerline is that you can do virtual 3-way lighting versus conventional with a traveler wire. It would be confusing though for an electrician checking and wondering how maybe three light switches talk to each other without a traveler.
