OK - here is another for your guys. I have installed HAI dimmers all over my house and I have one that is behaving very strange. It is a 35A00-1 HAI 600W dimmer. It is set to control 7 X 65W in ceiling spots above my kitchen island. They are the main source of light in the kitchen and they used to be set up on a 3way, one switch on either side of the kitchen. I closed off the three way and used a black and white to install a scene controller that works perfect. However, the dimmer at the other location is the one in charge of the 7 X 65W bulbs. The dimmer works great for a few hours, but then it gets very hot and will not turn off. When I double tap the bottom rocker the lights dim to about 20% and then stay there. If I turn off the breaker to that switch, let it cool, then turn it back on the dimmer will behave normally, once again allowing me to turn off the lights. I have removed it from all programming on the network and it is a standalone unit. I did this to try to isolate the problem - to see if perhaps the program was messed up not allowing it to work properly. The problem is still happening. The only thing I can think of is that I need to go to a 1000W dimmer, but I am not sure. I should have enough with a 600W dimmer to cover 7 X65W bulbs. Any suggestions...
