New to HA, HAI, and Haiku suite.
Prepping to wire my house - new build.
I plan to build a HaikuHelper interface for my new setup. I have a test bench up and running and have been playing with my OP II and the Haiku suite.
I have some scripting background so not to afraid to dive in deep.
I will be installing 40+ of the Ube wifi dimmers when they come out.
My question/thought is that the Ube dimmer will have a open API - Ube says it will be based on Rest. That should be easy enough to send commands from HaikuHelper with some scripting. The fun part will be in maintaining states when the dimmers are manually changed - its looks like the switches are going to send unsolicited UDP broadcasts on switch changes - how can we capture this in HaikuHelper and build state out of it.
I am guessing I can use one of the light schemas in the HAI even though it wont be actually controlling anything and trigger scripts with HaikuHelper off panel commands, but I need to be able to keep the panel status up-to-date on manual changes - can HaikuHelper help?
Thoughts. This is all theory at this point, hopefully I will be able to get in on the beta with Ube to play with some real switches.
