TonyStewart
Hi Wayne,
I agree there is a lot of parts to choose from, but i think i got it narrowed down pretty good now since i am placing my order soon. The informatio below is all resulting from my studies of this system and not tons of years of practical experience. The recent documents posted by Tony Stewart have been a great help, they are here nut you do need to register with SetNet (which is free and doesnt commit you to anything) to view them.
I guess it large depends on the size of the installation, but as a base for any size installation using ELK control it appears you need part number 364864-01 Lighting Interface, ALC to ELK M1 Automation Controller. It will do the basic communication between the ELK and ALC systems. This is a single product that connects directly to the ELK databus (hub).
If you don't go the ELK route and want to have something else control the lights (e.g. CQC) then you woudl need the following parts: 364644-01 Lighting Controller, ALC, Home Lighting Controller AND 364698-01 Lighting Interface, ALC, Serial Expansion Module.
From here on out its all the same no matter if you use ELK or something else to control the lights.
The above setup will give you 1 'branch' or 31 adresses (each dimmer/relay switch and scene switch needs an adress, AUX switches don't need one). If you need more than 31 adresses you will need part 364726-01 Lighting Interface, ALC, Expansion to create the additional branches.
The description below describes 1 branch, it woudl apply if you have the single branch of the normal or ELK controllers but also applies to each of the 3 branches of the expansion module.
The branch starts with a RJ45 port on the controller or expansion module. From there on out you can connect to the house in many many different ways. You can daisy chain from device to device or you can do single or multi level star topology. They all have limitations on their total cable length.
From my understanding for shorter cable runs you can simply use the 364645-01 Lighting Interface, ALC Distribution Module. This essentially functions as an ethernet hub and just provided a neat way to tie all the wiring together for you. For longer runs (or for those you want to be more 'safe') you can use 364677-01 Lighting Hub, ALC Branch Hub AND/OR 364736-01 Lighting Hub, ALC Branch Hub, Enhanced. Either one of these conditions and boosts the ALC communication signals for longer cable runs. The difference between then is the dipswitches on the enhanced hub so you can switch cable runs of and on during troubleshooting. Don't confuse each cable run from the hubs as a ALC branch, the hubs only tie the wiring together. You can only connect a maximum of 31 devices to each branch coming from the controller, not matter if you run it though hubs or anything else.
Initially i had planned to homerun cat5 from each switch location to the wiring room, but the quantity of runs i starting toget a bit rediculous and my conduits from basement to attic are starting to get full. I am thinking about changing strategy to put a box in the attic with some of the hubs and essential have 2 main locations to which everything is homerunned. The box is the attic will be reasonably accesible, but not as good as in the basement. Oh well..hopefully once it's all in i won't have to do much to it anymore.
This document has been a real eye opener for me and details very well how the wiring is done and the different options.
Well said! As far as sic0048's question about loaners, I will ask Onq to assist and advise you what I learn. Also the dimpled paddlesa re no longer available. Although we do have some color change kits and some of the dimpled paddles if you desire. Otherwise all other models are smooth and match any decora brand in shape/look. Colors are another matter. I could ship you some paddles for color samples.
TS
