I've read through many of the posts on this topic but haven't found an answer to what is probably a basic question.
I have programmed my dimmers and room controllers into my OmniPro using PC Access. All the devices are HLC (75+). However i would like to change the led intensity and create scenes in each room. I've downloaded UpStart and learned all the devices into it. I already changed the led behavior and that seems to be working fine.
My question is about programming in the scenes. I see you can do it on the devices themselves but I have a hard time with the 5-quick-presses and either way would take a lot of walking around. So if I do it on UpStart will it mess up anything with the status reporting or integration with Omni. All I would be changing is the light levels and responses to links in the switches.
Thanks for the help.
