Again, HST is following the normal software production development process. The beta was extensively tested. Build 1951 (production release) is a RELEASE. It is based on the many prior releases that each received much testing. HST also tests each release before it offers it as a download. If they waited weeks for additional internal testing, then WE would be waiting many months before ever seeing HS2.0. Anyway, I am signing off on this topic.
My suggestion:
If you intend on keeping a Homeseer system, you very likely will upgrade to HS2.0. Exception to this is if HS1.7 does everything you ever want it to do and you have stopped adding new functionality that might require someone else's plugin or script. With that situation, you can just keep the elecricity flowing to HS1.7 server and apply windows updates (which hopefully won't break anything).
But, if you do intend to further enhance your HS setup, upgrade now to save a few bucks. The next decision is whether you start your migration now, or after YOU are comfortable with the amount of time others have spent testing the latest release (which will continue to come) and HST continuing to respond to fix bugs, and add functionality.
If you are thinking of jumping on another HA platform (hardware or software based), then don't upgrade until you made that decision of what flavor.
My suggestion:
