Hi,
Recently I purchased a number of parts from hobby boards and I have been very pleased so far, except for a problem I'm now having with the temp/humidity board I bought.
Last night the software I'm using (oww) crashed randomly with no specific error message. I restarted it and found no readings were coming from my devices. After a bit of investigation, testing individual devices I found the temperature/humidity board to be at fault.
When it is plugged in with the other devices I can't get any readings from any sensors. Remove the board from the circuit and everything is fine again. According to oww there's no short circuit so that's probably nothing to do with it. But still the problem must be on the board itself. I've tried connecting it alone using both RJ45 jacks and the screw terminals. All produce the same problem.
Any ideas why this is happening?
-Chris
http://weather.cdpuk.net
-Chris
