Check your local code for when you are running low voltage and high voltage wires in such close proximity, especially if you are running them in the same conduit. The diagram is not correct, your EOL has to be in series with the NC relay contact, not parallel. Also, I would label the common as Negative and the NC as going to the zone on the M1. Electrically it makes no difference but for consistency I equate common with negative.v1rtu0s1ty said:Can't I use my 18gauge fire rated wire? And also, can you please verify the connection from the drawing I modified?
Thanks!
