BraveSirRobbin said:
gizzmo;
I understand your concern, but isn't the Elk M-1 UL listed now? Not sure why this would be a problem, but I'm certainly not an alarm code expert.
UL also lists night lights but not for fire alarm systems. UL Commercial Fire listing is several hundred dollars away from UL Residential Fire. The ELK M1 is not listed for commercial fire. Commercial fire also requires two independent means of communication. I'm not trying to be a jerk here but after a loss is when the lawyers pick this stuff up and throw it in your face.
After looking at the posted pictures I think this looks like residential sprinkler system, if that is the case then the ELK M1 should be fine
The M1 has been evaluated to the following Standards:
UL Standard 985, Household Fire Warning System Units
UL Standard 1023, Household Burglar-Alarm System Units
UL Standard 1635, Digital Alarm Communicator System Units,
UL Standard 1637, Home Health Care Signaling Equipment
ULC C1023-74, Canadian Standard for Household Burglar Alarm System Units,
ULC S545-02, Canadian Standard for Residential Fire Warning System Control Units.
UL Standard 1610, Central-Station Burglar-Alarm Units
UL Standard 365, Police Station Connected Burglar Alarm Units and Systems
UL Standard 609, Local Burglar Alarm Units and Systems
ULC S303, Canadian Standard for Local Burglar Alarm Units and Systems
ULC S304, Canadian Standard for Central and Monitoring Station Burglar Alarm Units
CSA C22.2 No. 205-M1983 . Canadian Standard for Signal Equipment
CSFM California State Fire Marshall
By the way, the correct terminals to connect the wire and the resistor ends to are the outside terminals. All initiating fire alarm circuits are normally open(close on alarm). This means that a short will cause an alarm.
