Next test is same as above but using Windows 10 (11) Pro. (Laptop or Desktop)
Testing here using one of two HP Elitepad G2 1000. Today one is running Ubuntu and one is running Windows 11 preview version.
1 - Download current version of STunnel
stunnel-5.60-win64-installer.exe
2 - Install STunnel
Version is very plug n play. It will create a cert for you and default config file is set up for GMail (in port 25 and out port 465)
Service installs itself correctly
3 - check your Windows 10 (11) firewall allowed apps to make sure STunnel is there. If not add it manually.
4 - install SnapLink and configure it to connect to your OmniPro panel.
5 - configure email as posted earlier.
6 - create an alert which is email only for alarm stuff
7 - exit SnapLink / restart Snaplink - IE: just to confirm that your settings are all saved.
8 - check your windows 10 (11) firewall allowed apps to make sure SnapLink is there. If not add it manually.
Tested it to work just fine.
BTW did all of this via Ubuntu Remmina / RDP to the HP ElitepadTablet.
Tablet connects to home network via Ethernet or Wireless or from the WAN via SIM card and OpenVPN to PFSense box.
[sharedmedia=gallery:images:1486]
2 - Install STunnel
