Nowplaying project Netremote Pro
I asked and this was the response:
Easy. Just create a button with the IR code 5001 0000 0000 0002 fc19 0004 0001 0000 and the path and name of the app as the IR name (for instance "C:\Program files\Zoom Player\zplayer.exe", with the "'s).
Of course this is for opening apps on the same computer as you have NetRemote. You need Girder to open one on another computer.
John
Ok I started to fix a couple bugs in the PPC version so I figured I would post the screen shots again as they were lost in the board crash.
Here is the main screen displayed on the PPC. There were takin in the non-full screen mode. Just tapping on the top left of the screens will make them go to full screen on the PPC.
This CCF library is contained in the Nowplaying project and can be downloaded here:
http://www.promixis.com/downloads.php?sect...netremoteconfig
John
Here is the zone control screen showing all 5 sones. The small LED lights on the buttons are updated via Homeseer. Red is 'ON", dark blue is "OFF" and "YELLOW" is muted (hardware). Each zone can be controlled and play a seperate CD. Also if you select the 'SYNC" button all zones will play from the master (zone 1) zone. I have not seen MusicLobbyPPC able to handle a screen like this.
Here is the Light control screen that has feeback from Homeseer. You can turn off and on each light as well as control the dim of each one.
Here is the latest album lister screen. It has buttons that allow you to list by letter grouping (A-C, ect) as well as by Genre.
John
I believe that the NR Pro does still work for the 30 day trial. MY current level of Nowplaying (not uploaded yet) should still work with version .9963 as I have not added any NR Pro features.
John
