The UPB signal generated could really be considered powerline noise, and different PIMs do it slightly differently. Rather to blame the PIM for doing it's job, a more likely cause is the switches that are controlling the LED lights. Not all switches were designed to control LED lights, and LED lights also vary greatly from one to the next. I'd try a different type of LED bulb, or try HAI's new switches designed for LED bulbs. Somestimes, you can also just make sure you have one regular bulb on each circuit and that might be enough to dampen things out. When you ONLY have LED lights, the power draw isn't enough to operate the lights correctly.
I agree. :mellow: check out http://www.ledlightshub.com/ for more about LED Lights.
