The fix mentioned above happens when there are many devices on your network. The OP2 NIC port is promiscuous and sees everything. So much that it takes the network port down causing all sorts of issues.
The issue of the network port disconnects is a documented issue with Leviton and HAI.
It relates to an early design of the network port. I didn't see the issue until I went over 100 network devices on my home network.
That said this does not relate to any app that you are using right now.
Questions I have for you relating to the OmniPro panel and use of PCA.
Does HAI PC Access work connecting to the network port on your panel?
PCAccess uses
1 - IP of the OmniPro panel
2 - two lines of keys that match your configuration
So does PC Access work?
PCAccess uses
