Looking for some advice. This is a tough one.
I have a powder room whose light and fan switches are mounted in a lousy location (guests typically spend too much hunting and groping around for them). I'd like to take the switches completely out of the equation by mounting a sensor so that the light and the fan automatically turn on whenever the door is opened -- and turn off when the individual has left the room.
Optimally, I'd have a sensor that recognized when the door was opened AND a sensor that would determine occupancy -- but that's more wiring and wall destruction (hand-troweled plaster) than I want for this room. On top of that, I'm also looking for a simple and straightforward solution that does not require integration with my M1 (although I will do it if I have to).
I guess those all-in-one, PIR-integrated, motion-activated wall switches might be useful -- but the orientation of my Jbox/switches in the room will not effectively capture the presence of a guest at the doorway -- or while they are occupying the principle area of the powder room. As such, my switch location would also require that the guest enter a dark powder room and close the door with the "leap of faith" knowledge that the light and fan will turn on by themselves (highly unlikely for first-time guests).
I guess a theoretical product that might solve my problem (if it existed) would be an alternate version of a PIR-enabled, motion-activated wall switch BUT where the PIR itself was remotable -- meaning that it could be hardwired to the switch but positioned in a remote location (3-5' away) so I could aim it in a direction that had a better chance of capturing the guest both at the door AND using the powder room. As if that weren't enough, I'd also like the switches to look and function like typical Decora switches -- for situations where the PIR fails to work -- or when the PIR needs to be overrided in order to keep the light or fan on for an extended amount of time.
I'm planning on installing UPB throughout the house and would be open to a UPB-enabled solution. I've thought about using UPB switches for both the light and the fan -- and then using something like Simply Automated's Input/Output Module with a ultra small PIR (like a Visonic SPY3) aimed in the right direction -- but the SA's I/O module needs to be plugged into the wall (which would make for an unsightly installation unless I hire an electrician to provide me with an standard outlet somewhere below in the sink cabinet -- which is also probably not to code), the SPY3 needs 12 volts all by itself, and I'm not sure what kind of additional equipment I'd have to deploy to provide an adequate level of delay to the input of the IO module so that I could avoid undesirable light turn-offs while individuals were still in the room -- but not physically moving for a short amount of time.
Anyone ever heard of anything like this -- or any other solution that might be appropriate?
Thanks for your thoughts
