apostolakisl
Lou, maybe in your area, LV is not inspected or looked at, but up here, it's definately inspected and checked over, both in the rough and in the completion stages. Firestopping is always verified no matter what, and the normal SOP is the contractor that made the holes is the one responsible for firestopping around here, which is really firecaulking more than anything else.
Some municipalities are tougher than others, but some won't even issue a C of O unless any cables/wires are terminated at a device, in other words, if you have a 4/22 sticking out of the wall, they won't issue unless it has a device attached or a blank plate covering it.
Also, most municipalities up here will issue a homeowner's permit for electrical (within reason) however whether or not the LV is covered under that permit or under a secondary permit for LV only is the AHJ's call. All the AHJ's I have dealt with will treat a HO rough the same as a pro run job.
As far as video and set top boxes and running cabling for such, Motorola and the other manufacturers came up with an agreement that the next generation of boxes will support both coax and category cabling and be able to be switched for either, as the legacy installs have coax already installed. If you're unsure at the moment, I'd honestly recommend running both, as the cabling isn't expensive and even installing a 4" box and single gang mud ring is a trivial expense to allow enough room to work with behind the wall.
Certainly any locale can write laws anyway they want. But, frankly, if they are telling you how to do your LV, they are just abusing power. What possible reason could there be? The purspose of codes is to ensure a certain level of safety for the occupants of the structure and the community that surrounds it. What could they be inspecting for in LV that has anything to do with that? A LV install could certainly cause a threat, but that threat would be the result of the LV install basterdizing one of the other installs. Like mixing HV and LV, that would be covered under the HV rules. Or drilling holes through firewalls, that would be covered by the fireblocking rules.
So, I would be very curious to hear what the LV chapter of the inspection manual has in it.
