Hi all,
I purchased a Humidity/Temp/Solar sensor kit along with a six-channel hub from Hobby Boards. I've had the hub working with a couple of DS18S20s and owfs with no problems. But no luck with the HTS board. The board is showing up just fine in owhttpd, but the sensor values are out of whack:
I'm a newbie with the solder iron, so I wouldn't have been surprised if I screwed up. I actually bought two boards, so I assembled the second board, taking extra care to test each connection.. But I got the exact same behavior from the second board.
The fact that it disappears from owfs when I close the parasite jumper tells me that something is screwy with the power supply.
Any thoughts on what I did wrong?
Joe
- humidity: NAN
- temperature: 0
- HIH4000 / humidity: NAN
- HTM1735 / humidity: -41.98
Joe
