A couple of days ago I got the Comcast Digital TV service installed. I have had internet through comcast for years and never had an issue. The reason I mention the tv install is because for the first time I have installed a splitter on the wire coming into the house.
So this is what is happening. I think it is more of a router issue.
If I connect the computer directly to the modem it works fine...the problem happens the minute I add the router to the equation. the IP fields etc were all zeros. I reset the router and it started working. A couple of times the unplug the router and the modem routine worked but now it only works if I reset the router.
Every couple of hours the internet connection dies and I cannot get internet on any of the PCs. The other check is that my VOIP phone stops working. The VOIP box is connected directly to the router and the PCs are connected to a switch.
Please advise as this is causing major headache.
What could be causing this????
regards,
regards,
