SnapLink replacement
I'd like to try it out on an old Android (I use an iPhone normally). What's the minimum version of Android OS it needs to work?
The minimum is Android 8.0 (Oreo). So it works on the cheapest no name Chinese tablets that cost $38 up to the latest and greatest.
Lots of updates to announce for our HAI/Leviton systems (Apple Platforms)!!!
Myro:Home Pro 1.0.0 has been released:
The most powerful way to control your smart home. Myro:Home Pro, the next generation of Myro:Home, brings HAI and Leviton automation together with Apple HomeKit — so every device in your home lives in one place.
• Way to many features to address, but this has everything CarPlay, Widgets, Watch app -- completely rewritten from the ground up.
Link: https://apps.apple.com/us/app/myro-home-pro-for-leviton-hai/id6630364676
The new version of Myro:Home Helper 3.0.0 (macOS only) has been released:
• Scripting is here! - A JavaScript scripting engine for custom automation with event-based triggers, scheduling, and device control.
• Graphing is here! - Log and view Thermostat and Aux Sensors (Temperature & Humidity) changes easily.
• Vestaboard support - Now your Omni/Lumina messages can be displayed on Vestaboards!
• Sense Energy Monitor support has been added!
• LeMetric TIME support - Now your Omni/Lumina messages can be displayed on LeMetric TIME!
• Now daily automatic time sync when 'Sync Controller Date/Time' is enabled
• New API endpoint for manual clock synchronization and device support
• Tested on latest MacOS 26.
Link: https://apps.apple.com/us/app/myro-home-helper/id1334844181?mt=12
Myro:Home Helper
Myro:Home Pro for tvOS 1.0.0 has been released:
Turn your Apple TV into a dedicated camera dashboard. View your security cameras on the big screen — right from your living room.
How it works
Myro:Home Pro for tvOS works seamlessly with the Myro:Home Pro iOS app. Simply select which cameras to display from your iOS/iPadOS, and they'll appear instantly on your Apple TV. No additional setup required.
Features
• Quad View — Watch up to 4 cameras simultaneously in a 2×2 grid
• Single View — Full-screen display with automatic cycling through your cameras
• RTSP & MJPEG — Supports IP cameras with RTSP and MJPEG streams
• HomeKit Cameras — View your HomeKit-enabled cameras directly
• Hardware Accelerated — Smooth playback powered by VideoToolbox
• Audio Support — Listen to camera audio when available (muted by default)
• Siri Remote — Swipe to switch cameras, press play/pause to control cycling, swipe up to toggle audio
• Live Sync — Camera changes made in the iOS app update automatically via iCloud
• Burn-in Protection — Overlay elements shift subtly to protect your display
Requirements
• Apple TV (4th generation or later) running tvOS 17.0+
• Myro:Home Pro app on iOS with an active subscription to configure cameras
• Cameras must be accessible on the same network as your Apple TV
Link: https://apps.apple.com/us/app/myro-home-pro/id6760438990
Please provide as much feedback as you can -- would love to know thoughts good and bad!
Cheers,
Danny
I have a stupid question,,, I dug up my old Samsung Galaxy Tab A. Its running 8.1.0. I downloaded your app. There is no pop-up for getting started. How do I enter the config information?
Fixing this issue now -- certain Android versions are skipping the onboarding step -- fix should be in Play store soon (anyone else, you can double tap or swipe down from the header to get to the controller list in the meantime).
Update: this has been corrected in v1.0.6
