Frank Hagan
I installed a GE NX-4 system over the weekend in our desert cabin. After programming, I get three short beeps which the keypad manual describes as "... trying to arm with the READY light off if 'force arming' has not been selected." (NX-1300E keypad). The service light is illuminated, Zone lights flash with zone 2 and 4 lights pulsing. Upon entering the service menu with [*] - 2, number 5 is illuminated ("Zone Trouble"). Pressing "5" illuminates zone 2 and 4 as the ones having trouble.
Zone 1 is the doors, using the same sensors that are in use on Zone 2 (the windows), both wired in series. As I was installing, I used a continuity tester to make sure that when all the windows are closed, there is continuity. Open any window, and the continuity is broken. Zone 2 has 4 sensors compared to the 2 sensors on Zone 1. Neither zone has the EOL resistor installed (installing it at the panel as a test didn't make a difference).
Zone 3 and 4 have a single sensor wired to them, with the magnet taped to them, for testing. Zone 3 is OK, but zone 4 is not.
I'm thinking the problem is probably in programming the control panel. I have Zones 1 and 3 as zone type "3", with the "Entry/Exit Delay 1" feature. Zone 2 and 4 are programmed as zone type 5 "Interior Follower with Auto-Bypass Enabled". While I didn't swap out the wires, I did try programming Zone 2 and 4 as type "3", but they still report errors.
Question 1: How do I troubleshoot this? Is testing ohms resistance a better way than a continuity test to test the circuit?
Question 2: I have a 180ma stobe connected to AUX1 on the NX-4 programmed to activate on "Any Siren" (#7 on the table), with a zero in the segment 2 field of location 47 (which should make the output follow the event). Because of the zone issue above, I'm not able to trip the normal alarm, but the siren tamper function does work. When I disconnect the siren's common, the keypad squeals and upon reconnecting, the siren goes off. The strobe does not. I'm hoping that perhaps "any siren" means "any siren except the tamper feature". I won't know until I solve the zone problems, but any insight you can give would be appreciated.
Question 3: Where do you hook up the motion sensor positive lead? The schematic advises to connect the common to COM, but gives no advice on the positive power lead. Can I use the POS terminal (labeled for the keypad), or should I connect it to one of the AC Input terminals?
