I have just completed my first phase of installing UPB on the main floor of the house. So far about 10 switches and 1 remote (USR). Everything seems to work well, no noise, signal on same phase is about 80 and on opposite phase is about 30. Anyhow that is just background, since I see so many other posts about installs not going so smooth.
My questions are about the USR -- it has a green light and does not change colour when the light is turned on. I thought it would change colour when the load was on, correct? Also it is green and not blue -- do you know if SA is planning on making blue light USRs?
My observation is that that when I set the load to come on to 100% at 20 seconds it comes on to 100% in around 5 seconds. I am sure that I programmed the switch as I was playing with a number of different ramp rates. The switch is a US240 version 1.15. I don't really care that it is quick as I can play with the timing and generally all I really use is 3 second or less ramp.
What are other people seeing?
Thanks in advance.
Thanks in advance.
