What size speakers?
kimvi
I have 2 bedrooms, 16x16x10, that I was thinking of putting in-wall speakers. I planned on putting in 8" In-wall speakers at about 4' off the ground. I was about the buy the speaker brackets and decided to ask the enthusiasts on the board before placing the order.
1. Is this overkill? Would 6.5" speakers be just as good in a room this size?
2. How would you configure this room?
bfisher
It depends on your listening preferences, but to me, even the 8" won't be sufficient except for background music.
There isn't a huge difference between 8" and 6.5" speakers for music reproduction - generally the 6.5" are slightly cleaner since they aren't trying to reproduce significant bass.
My personal opinion (and what I always do)... include a small subwoofer. I have no experience with in-wall subs, I usually just buy a small sub and hide it on the side of a couch or dresser, etc. For music only, you don't need a huge sub, most small ones work wonders. I always buy powered subs, but passive might work as well if you have enough amp power.
Wiring is a little different with a sub. Most subs accept speaker level input (a requirement I always look for) so I wire from the amp, to the sub, and then to each speaker location.
As for how to orient the room - first requirement is wiring accessability. If there are no restrictions, then I generally try to orient it so stereo sounds right based on your common listening postion. If you listen in bed, have speakers in front of you, etc.
Good luck!
chaseru
I just finished installing speakers for my whole house audio system. For larger rooms > 14x14, I installed at 8" ceiling speakers. In smaller bedrooms, I used 6.5" ceiling speakers. In great rooms, I installed multiple 8" speakers.
For the master and family rooms, I'm using the 8" ceiling speakers for whole house audio and then using a automated speaker switch to change them to rear surrounds when using the 5.1 receiver for TV viewing. Also, for these rooms I installed 8" in-wall speakers for L and R channel for the 5.1 receiver. I didn't install in-wall center channel speakers since I don't want to commit to their placement. I can use some voice matched bookshelf speakers for placement and furniture flexibility.
I'm not installing the in-wall speakers until I move in to make sure the placement works for the furniture and ultimate listening positions, but the speaker manufacture recommends that the tweeter should be around ear height. You also don't want to put the speaker to close or too far away from the corners. At least 1/3rd the distance from the corner to the midpoint of the wall was a rule of thumb I heard (if that made sense).
Not too hijack this thread and make it a whole house audio discussion, but the speaker performance is highly dependent on the amp used. For my great rooms where I use multiple speakers per zone, I'm using a multi channel amp. Even though this amp is not high-end, it pushes the sound out of the speakers (esp. the bass) far better than the remote in-wall amps I use for zones in smaller rooms. The multi-channel amp gave me that gitty feeling that I haven't had from listening to music since I owned a portable DJ system in high school.
I would include a provision for a sub-woofer if you want to have solid low end response to music listening or if you plan to use the location for home theater.
Finally, when you install the in-wall or in-ceiling speakers add some fiberglass insulation in the stud space, although don't stuff the insulation.
