Who has Nuvo Music Port?
From what I've read, it syncs with other PCs on your network to its 320GB internal drive.
PM'd you the ProZone login information.
Yep, from the training webcast a couple of weeks ago, the "sync" is a utility on each PC that copies music to the server. The server only plays files from its local hard drive (and hopefully in the near future from an attached USB drive).
Jeff
Seriously?? Nuvo is discontinuing the MP...ok..nobody ever buy what i buy..first ALC a few weeks ago and now MP..WTF!!
I haven't read up much on the Music Port server...but assume it's terribly more expensive.. do you load the music onto it or can it play from a NAS?
The reason i ask is that my music library (which the MP uses) is located on my server. But my desktop itunes accesses it as well. The way it currently works is that if my wife buys a new song from itunes it makes it into the normal library and with the next Music Port scan..which it seems to do every 15 minutes or so it automatically becomes available for the MP and shows on the webGUI and keypads. I REALLY like this feature and wonder if the MPS can actually do this?
In the end if i were to have the music library stored on my server what is the point of the MPS..it would just 'play' the music..just like the MP does.
Can somebody PM me the access info for the new prozone/support section..i want to download the latest MP software.
I can understand them replacing the MP with the MPS, although I'm very glad I have the MP! From the dealer/installer's perspective, the MPS is a much easier device to support. The MP is more a "bunch of parts" that has to work with either a PC they build, or worse(!) something the customer already has. Although I do wish they'd just keep it around for us DIY types that don't need the "solution".
And yes, when you've already built a music server, the "Music Port Server" duplicates a lot of that functionality, which is why the MP is such a good fit for both of us!
Jeff
I think I read somewhere that the MPS4 only provides 3 sources, while I have my MP configured for 4.
Phone MC at AO for current special of 1K off MSRP. ;)
I'll stick with my MP, if I can get internet radio.
Weird stuff tonite -
I finally got a chance to start stress testing and ran 2 large MP3 Playlists from the HTPC to the MP.
The first stream plays fine. The second stream is weird - it plays the music fast, skipping its way through the song at rapid speed!?! This is new - now I'm just not sure if its related to the MusicPort software change or something else.
If I go with one stream only, things are fine. Its the instant that I try for 2. Very, very odd. I may roll back the MP software on the weekend to determine if its a MusicPort or a Delta soundcard issue.
Just reporting back in case anyone else runs into this problem... it was caused by a bad new Delta driver release - I rolled back my audio drivers on the Delta 1010 and all is well.
I sure hope we MP'ers see internet / satellite radio before support for the MP is dropped... I love the MP for my HTPC/NAS setup - the MPS doesn't fit into my requirements very well. The last thing I need is another computer to maintain.
Phone MC at AO for current special of 1K off MSRP. :)
MPS4 provides 4 zones.
Thanks, Broconne. Can't find the link, I should have double checked. I think it was in a recent Renovia press release, which was (now) obviously a typo.
If Nuvo is discontinuing MusicPort, I need some fast advice!
I purchased a Grand Concerto system that I found a good deal on ahead of my house being completed (still quite a few months off). I figured I'd purchase MusicPort once the house was finished & the GC was installed.
Sounds like I need to act fast if I want to buy MP. I have no interest in the MP Server, the price is high and it's just duplicating a lot of the hardware I already have.
So, the advice I need.. Should I jump into an MP purchase right now? Is the current implementation solid so that it'll be a good long-term solution? I am mainly interested in being able to play on the GC whatever music I have sitting on my hard drive (CD rips, etc), we're not big on using online music services.
Assuming you guys support purchasing MusicPort now, knowing that it's going to be discontinued.. If you have any recommendations on where to buy at a discount, please drop me a line on that too :D
Thank you!!
Take a close look at the MPS4, would be easier than maintaining and configuring a dedicated music server PC.
If you use the MP, you'll need, I think, at least 2 dedicated serial ports on the PC - 1 for control, and the other for programming. Maybe it can be done with 1, but I'm using 2, via an Edgeport/2 USB-serial adapter.
You're probably better off with the MPS4, than the MP, because of the lack of FW updates, if the MP is discontinued. I'd like to keep my Nuvo GC for a good 15 years, if possible, and who knows what online music services will be offered in the future, that I won't have access to, without FW updates.
PM sent. :D
Hi,
Thanks for the response!
No problem regarding serial ports, I have plenty to spare! (I picked up 2 Edgeport 8's via the $25 deal on Ebay, I think someone posted about that either here or on the CQC forums).
Even if you bought the MPS, at some point it will be discontinued for a newer model as well, right? :rofl: It seems like the cost different between MusicPort & MPS is significant enough that if MusicPort became so obsolete/unusable many years from now, one could make the decision to buy "the next best thing" that exists then with the money saved now?
Important: can someone confirm if MusicPort requires a "dedicated" server? Would there really be an issue running CQC and/or a couple other server apps on the same machine assuming the PC is powerful enough?
Thanks!
Thanks!
Hey Speed,
I'm running Xlobby/Girder and I watch movies from the HTPC that also runs the musicport software. No performance issues noted to date, and I have a older AMD 4600+ CPU and 3 GB's of RAM. (I found that the extra ram helped things, tho - I used to have just 1GB before installing the MusicPort.)
hope that helps
Hey Speed,
hope that helps
That helps! ;)
Thanks! I'm off to find somewhere to buy MusicPort from!!!
ok..i thought i had read about some of you with the MP being able to get Pandora now..is this with the Nuvo version of the MCS or something else?
If this is with a version from Autonomics..is it just a short term trial or does it work long term?
In the more recent Nuvo MP MCS GUI there is a RADIO button and then it shows something for Pandora, but it doesnt seem to do anything. In the MCS software there is also nothing to configure it seems.
So is Pandora ready now or not yet? I'm pretty confused from all the posts in this 20 page thread.
